Beeping Sound
    Thanks 4BW
    Actually I used the boat all last summer and then it sat from October to Jan. I noticed the old RAMS were leaking so I changed them out.
    I took the boat out this month (about 3 weeks ago) and noticed the beep. I knew I had to complete the annual so I did. I took it out last weekend and the beep still occurred but only when I used the TAPS....I tried to narrow it down to what I was doing when the beep occurred. 3 weeks ago I thought it could have been the impeller from sitting….but that is changed now.
    It could still be a fluid level, I know I only put about 2 qt's in for the tranny....but I also checked it cold...not hot. I need to get back out to the lake and check it the way you mentioned to eliminate this.
      Does that change anything? That this beep was happening before and after the annual?
        beeping
        As far as I know, the sensors that will cause the alarm to sound are: oil pressure, ECT(engine coolant temp), sea water pressure, or perhaps a faulty or unplugged MAP, TPS or knock sensor. The easiest way to find out is to have your dealer see if there are any active ECM codes and go from there. Of course, if it is not an engine alarm, it could be something like a depth alarm setting? Just a thought.
