Is it possible tp replace a section of the plastic trim that holds the rubber rubrail around the perimeter of the boat? Apparently, I cracked a section of mine and now the bottom half of about a 2 to 3 foot section has fallan off and the rubber bumprail part pulls out easily there. I will be in Abilene in about 10 days and could deliver the boat to the Tige building if needed or can I replace the broken part myself?
Also, one of my rear vent covers has come loose and I pulled it totally off before it fell off like the rubrail part did. I just don't want to lose this piece. What can I glue it back on with. Seems like I used marine epoxy last time but it didn't hold as hold as I would like.
David
David
David
David
