This originally was a question direct to one of the members but he made a suggestion of posting this thread to help everybody else that could need something similar. That being said: I already have been in the forums quite a few times and found some interesting info. For example filling the spray pockets. which gonna be my next project.I will post some pictures of the 454 magnum EFI engine that this boat has.
Originally Posted by Vitocha
Hi, I'm new here, I live in Monterrey, MX and actually own a 96 pre2002wt and the main use is wakeboarding (intermediate level and sometimes beginner hehe). Sometimes not getting a good wake is really frustrating. That why I'm here learning and asking for help.
So basically these are my main doubts.
1. While doing some re-wiring, taps system was disconnected and along the way I forgot the wiring order and had to do some test up and down. Now I don't know which position is for what, not sure if the gauge is telling me the correct info. So basically for this kind of hull (96 pre) - plate up or down will be for slalom or wakeboarding?
2. What would be your recommendation when it comes to adding weight to the boat for wakeboarding - ballast setup (front - middle - rear). How much & how to distribute it along the boat? Im running the 454 magnum engine.
And with this setup which position is recommended to use the taps?
3. Taps & weight setup for wakesurfing. I have tried number of times, but still not making enough wake to find a sweet spot and sometimes a little bit of scareness when seeing water to close to enter the boat on the rear corner.
We are kind of wakesurfing because we still do it holding the rope.
I'd really appreciate your help and opinion in this matter. At this time, my first baby was born so there is no budget to even think about changing to another boat. I'm really passionate about wakeboarding but in need to take the best advantage possible of current boat.
Thanks in advance. Best regards
Victor
Victor
