Teak wood platform care...
    I bought some teak wood oil, fine sand paper, a paint brush, and some towels. I plan on sanding the platform down to smooth surface, then brush on some teak oil, let it sit and then add another coat of teak oil. Is that correct? Better ideas? Thanks
    "Well it's 1am, time to go home and spend some quality time with the kids."
    -Homer Simpson
    The only other thing I have read is to use Savograns Superstrip to remove any existing finish off the platform. Also, use TSP cleaner after you use the superstrip and use the TSP again after you have sanded it.
      I don't think you would need the superstrip unless the teak has had an actual finish placed on it. If it has only been oiled, then it will be fine without.
      But many of us use the teak oil finish that you can get at Lowe's and really like it. Mine is sitting in the garage, and has not been used yet, but there are some great pics of teak platforms in another thread. If you use the stuff at Lowe's, then you would need the finish remover.
      Be excellent to one another.
        Here is the thread with a lot of good information:
        http://www.tigeowners.com/forum/show...eak+oil+finish
