Originally posted by ecutter
View Post
NEW 2012 Z3 in Denver at WWS!!
http://wake9.com/
Originally posted by ecutter View PostThe 409 is a 5k upgrade.. They have been running 340Hp
Motors in the 24Ve with no problems here at altitude. So
I think after talking with Bill and he was talking with
Tige.. the 343 actually pulls harder out of the hole
but loses to the 409 during Mid range and top end power.
Since 90% of what we will be doing is surfing, 10% Wakeboarding I think the 343 will be ok. I can always do a different prop.
Also the 409 comes standard with a closed cooling system. This is a plus for us living around salt and brackish water. I never plan to put the boat in these waters, but I would have that option if needed.
Tigé Jedi
- Feb 2004
- 5557
- St. George, Utah
I call BS on the whole theory that bigger engines are going to burn less or equal fuel. That idea seems to usually be touted by sales people who make money selling more expensive boats.Be excellent to one another.
Originally posted by talltigeguy View PostI call BS on the whole theory that bigger engines are going to burn less or equal fuel. That idea seems to usually be touted by sales people who make money selling more expensive boats.I do all my own stunt work. hey ya'll watch dis.
Originally posted by talltigeguy View PostI call BS on the whole theory that bigger engines are going to burn less or equal fuel. That idea seems to usually be touted by sales people who make money selling more expensive boats.http://wake9.com/
I kind of want to go with the 409. That motor wraps out at almost 6k rpm too! You will definitely notice 66 horsepower (and who knows what the torque difference is), especially up here at altitude. Will it be more efficient? No idea, it's possible. It will definitely use more fuel at higher speeds and rpm's.
Is more motor ever a bad thing!
Its a boat, its gunna guzzle gas regardless of the motor, in that big of a boat with lots of weight it may be better to have the 409 than the 343. The 343 is almost too much in the little rzr but our boat uses much less gas than any other watersports boat ice been on. It is a little over powered but considering all we do is wakeboard and surf the motor has spent most of its life pushing 5500-6500 lbs around. In a z3 you're looking at 4600lb dry weight plus 2300lb ballast plus your whole crew that's an easy 7500-8500lbs or more...the 343 will be enough but it won't give you the same holeshot by anymeans....
My buddy has the MCX in his x25, a4200lb boat, with any ballast over stock its takes in excess of 30 seconds to plane off... Just something to consider.
