Looks like it may be a good place to use stainless steel!
broken swing tounge bolt
Originally posted by gman View PostLooks like it may be a good place to use stainless steel!
70,000 - 18-8 stainless
70,000 - Type 316 stainless
80,000 - nickel copper alloy 400
120,000 - grade 5 rust resistant zinc
170,000 - grade 8 zinc yellow-chromate
180,000 - grade 9 zinc yellow-chromate
In looking at the swing arm there is a bit of slop between the arm and the bracket.
I'm going to slip a SS washer in the top & bottom of the joint to help reduce the clunk I get on the road.
The washers would still allow the arm to pivot, but should reduce the wear on the bolt as the joint works.
