Have tried doing some internet research, but keeping running into sites, or companies that no longer exist. I have a Extreme Phat Tower, on a used Tige I recently purchased, and would like to upgrade some of the worn out parts if possible. Anyone have any info, or other companies that may use the same faom sleeves and bungie cord sets up? Any info would be great......
Phat Tower , or XPT
I have the same tower on my 24v. For the foam fingers (if they are not missing chunks out of the foam and are just discolored) I used this:
https://www.amazon.com/Detail-Doctor.../dp/B00B9EQHFS
It restored the shine of the foam and stopped the black rubber mess from getting on my hands, boards, etc.
As for the bungees, I replaced all of my bungees using the bungee below, a heat gun, and zip ties. You can remove the foam, cut the bungee to length, heat gun the ends to prevent fraying, then install and either tie a knot or zip tie the end inside the metal finger.
https://www.harborfreight.com/25-ft-...oks-99891.html
Hope this helps!
Kyle
You can remove the
