We are looking at buying a 2009-2011 Suburban and plan on using it to tow our 2010 RZ2. They are spec'd to tow up to 8100 lbs which would seem to be plenty. The 3/4 ton can tow 9600 lbs but you take about a 5mpg hit. I'd rather get better mpg if at all possible.
Does anyone have any experience towing a comparable boat with a 1/2 ton Suburban? Do we need 4WD or will 2WD be sufficient?
Last year I bought a new F250 and it tows our RZ2 with ease. I'm not expecting the same results but curious if it will handle the task.
Thx as always...
Thx as always...
