DIY Board Racks - $35, 1.5 hours, and 4 beers
    I am probably like most of you, and you hate having your garage cluttered. So with the latest obsession of wake surfing new boards have made their way into the garage. I had just been laying them anywhere I could along with the wakeboard. So this weekend I figured I could organize things a bit.
    The materials are 2 1x4s, 4 8ft dowels, 12 washers and 5 inch threaded bolts. Here is somewhat of the walk through from beginning to finish.
    The materials:
    The spot where they are going:
    The 1x4s drilled:
    Both racks with the dowels on them:
    The finished product:
    I now have a place to put our snowboards now. So these racks will serve a dual purpose.
    Nice work. You gotta love having a place to put the awkward stuff.
      I don't park my truck in the garage because it's TIGHT TIGHT fit because of my work bench. Plus, I am always swapping our dirt bikes, my street bikes, and my drum gear. I just didn't have a really good place to put things after taking them out of the boat. So this is what I came up with, and I thought I would share. Maybe inspire someone else to try and unclutter their garage.
        What did you use to cover the dowels with?
        Looks great, and a pretty easy looking job.
        Be excellent to one another.
          What is the spacing?
            @talltigeguy - I used pipe insulation (home depot link). Cost me roughly $1 a piece, and I bought 4 of them.
            @TeamAllen - Spacing is 1 foot.
              Looks Good! What's the second board on the rack - looks black?
                That board is a Grindwater Mauka. I need a fat boy board. HA! I weight 225-230, and I was afraid that the Shaka board, which is rated up to 230 wasn't going to cut. So I went with the Mauka which is rated to handle up to 300#. The two boards are similar, it's just that it's 4 inches shorter. After riding the Mauka I believe I could actually get away with the Shaka. I spent a good month researching boards after getting my IS stolen out of my boat.
                  Nice project!
                  How do you like your Slingshot setup?
                    Question:
                    Did you glue the dowel's into the holes?
                    I assume the 5 inch threaded bolts and washers were to attach 1x4s to the wall--or--was they used to somehow attach the bottom of the dowels to the 1x4s?
                    Looks great.
                      4 beers in an hour and a half?
                      Git er done!
                      (explains why the last 3 dowels are all crooked.. bahaha)
                      So this monkey walks into a bar...
                        And when they are in the garage, no young hoodlem will steal them out of your boat!
                          I desperately need to do this to. I just moved into a new house with a 3 car garage, but I can't decide how I want to set up the garage yet. Plus I've been having way too much fun skiing on my time off.
                            Originally posted by murphini View Post
                            Question:
                            Looks great.
                            No, I used deck screws to screw the boards to the wall.
                            My buddy has a drill press. So we drilled down the center of the dowels 3 inches down with a one size bigger drill bit. The part of the board facing the wall was pre drilled, and recessed about 1/4 of an inch. placed a washer in the hole, put the screw right through it and the board, and screwed on the dowel.... Hope I explained that right. HAHAHA!
                              How would you modify this for a boat Shed where I can't drill into the walls? How would you suggest modifying it to make it stable on the floor?
