Use TAPS when wakeboarding?
    Originally posted by Ewok View Post
    Don't be afraid to experiment either, you can adjust speed and taps while he's riding behind the boat. He can use hand signals to you in the boat to speed up or down and for you to adjust the taps up and down. Tell people in the boat to move around to help clean up the wake as well. Play around with the settings in small increments and you'll have your wake dialed in in no time.
    I use this method all of the time! It is probably the best way to create the best wake for your heelside jumps.. which are the easiest.. This is especially helpful when you start wakesurfing.. which you will love.. i rarely grab the board anymore just because I'm prone to injury on that thing.. but yeah.. move peole around.. move the taps up and down.. and do it while someone is riding because when you're towing something the whole wake tends to shift depending on the weight of the boarder.. hope this helps
      Just following up after experimenting last night. Speed at 22, rope 70' and TAPS at 7 worked perfectly - wake was slightly narrower and gave me just the right amount of pop. White trash was never really a problem, we've always had a pretty clean wake. Thanks for all the advice and feedback!!
