I got a question about how my 4Runner towed my RZ2 in a different thread so I thought I would start one to answer questions and give tips if I can.
My 4.7L V8 4Runner is rated from the factory at 260hp@5400 rpm and 306lb-ft of torque @ 3400 rpm rated to tow 7,000lbs (7,300 lbs 2wd). *It pulls great, I recently moved from TX to WA and if you read the thread below, it will explain how much I overloaded the boat and trailer with moving stuff. *If you tow with a little truck I recommend getting 4wd, Toyota had a nice locking center diff and gearing for 4wd low, which helps put the torque on the wet and slippery ramps. *I have not had any issue pulling my boats out of steep wet ramps with my 4runner.
http://www.tigeowners.com/forum/showthread.php?t=13920
Sadly, the 2010 4runner dropped the V8 option, but added a bigger V6. *It's now a 4L V6 for 270hp@5400 rpm and it's rated to tow 5,000lbs. *I don't recommend pulling more weight than the truck is rated for, and most would be surprised how much their boat and trailer weighs above the dry weight listed on the Tige website. *My boat is 4150 dry weight but with the trailer, full gas and gear, I'm looking at about 6500-6600 lbs on a regular day.
The other little truck we looked at when we bought our 4runner is the Nissan Pathfinder. *The 2011 Pathfinder still has a 5.6L V8 option good for 310hp@5200 rpm and 388lb-ft of torque @ 3400 rpm, rated for 7,000lb towing. *The new jeep Cherokee is also a nice small truck with a V8 option good for 6-7k lb towing as well.
So, to those with little trucks as tow vehicles, post up your impressions, tips and tricks. *Pics too if you want to, here is a pick of my little rig during the move:
