Okay so i got my hands on a used perfect pass wakeboard cruise. I started then install yesterday and things havent been going as well as i hoped they would. First off i am missing the L bracket and a fellow TO member sent me something that was suppose to be the L bracket but it isnt. I tried all day to make this little "doomahicky" work but it isnt. Can you buy this bracket anywhere or just from perfect pass? another thing was the guage install. I planned to replace this blank 2.5 inch guage with the pp switch. when i popped open the dash i see that there are tons of wires hooked up to this little blank guage. wth is this thing! another problem im having is tying into my exisiting paddlewheel. it is a transom paddlewheel and i know they arent suppose to work as well. but it displays speed fine on my speedo and i dont mind having to feather it during turns. anyways, do i NEED the adapter to tie into it or can i just use some old wire. if so, how do i plug it into the master module. other than that i got the servo mounted and everything else good to go. just need a little bit more answers. thankyou!
