Shoot thru depth finders
    My 98 2200V does not have a depth finder. I don't want a skimmer. Can I just get a lowrance shoot through transducer, epoxy it to the bottom and be done with it?
    The reason I ask is that I read in the instruction manual that it needs to be a solid floor or else I need to drill a hole through the first layer and foam and then place it agains the final lay of fiberglass. Needless to say, I am not too keen in putting a 1.5" hole halfway through the bottom of the boat.
    Soooo, is the bottom of my boat solid fiberglass or is there some sort of foam sandwiching going on?
    Thanks
    Bakes
    I have a 2002 20i and had the same issue. I bought a Hummingbird HDR 610 and it works great. It actually fit perfectly into a blank gauge hole I had, so Install was a snap. As you have indicated the transducer epoxies on the bottom of the hull. Because I have a direct drive I was able to mount it right beside the center drain hole. My install took less then a hour.
      I did basically the same thing, just different models and different products. I mounted mine just aft of the tranny and fore of the shaft. Works great. Pretty easy job that is a must have. The bonus was that it slid right in to the clock spot in my gauge cluster, right above an empty switch. 2 beer job at worst. It's been in there for...ever.
        I did the Faria one...they have two style transducers now. I have the transom mount one which I epoxied it to inside of the hull like Nickypoo. The other nicer one has a two piece setup. You epoxy the outer ring to the position and placement (helps account for the curvature of the hull). Then fill it with a fluid and screw the transducer on. I've heard the later works better.
        Mine works 95% of the time, but sometimes throws bogus numbers.
          I have an '07 20i with the shoot-thru and it works fine for avoiding shallow water. Not much good for fish-finding. LOL. (I dont let fish in my boat... or poles.. or hooks.. or Nascar fans)
          So this monkey walks into a bar...
            Thanks all. Epoxied it in place last week by the center drain plug and it works great. It's nice to actually know how deep the water is. It wasn't a big deal when we lived in washington and skied the same, clear lake every time. Now in Louisiana the water is far more murky and things change on the river
              Are F1 fans OK?
