I've been unsuccessful "tuning" the noise from my Bimini. Has anyone found a solution to this??
It sounds like baseball cards flapping in your bike spokes (if you are old enough to remember that).
Loosen the Bimini and noise starts at lower speeds.
Tighten and it kicks in over 30.
It is very loud -- much past annoying.
The flutter is on the outside edges ... between the front cross bar and the back cross bars.
On a sailboat, the leech of a sail will flutter like this as the cloth stretches, but there is a tunnel sewn in with a thin line down thru it so you can tighten it to remove the flutter. Unfortunately, there is nothing like this on the stock bimini.
