Graphics on 2011 coming off??
Excess contact cement comes off with acetone. Most contact cement is neoprene based but is a "flammable" or "non-flammable" form. The non-flammable is water-based and is not supposed to last as long.
I went with the flammable and did not see any effect on the gel coat where I wiped away excess. But it was not on there very long either. Perhaps test in a discreet spot.
If you are worried about your gel coat, try the non-flammable and see if it holds.
On the filling issue, I try to set the pump on the super slow pumping when I know it is getting close to full. I haven't had much gas spill over in a long time but then I also only pump gas in from a gas station a few times a year. (mostly syphon 5-gallon tanks in at storage)Friends don't let friends POWERTURN
