2005 22v Onboard cooler drain?
    Wondering if someone could tell me where/how the water when drained out of the built in cooler gets out of the boat? Does it just simply drain into the bottom of the hull then run back to the bilge area under the engine or is there tubing that gets it from the bottom of the cooler to some other place. Most importantly, I am wondering if there is a hose connected to the bottom of the cooler or just a hole in the cooler that drains into the bottom of the boat? Hope this question makes sense.
    Just drains into the hull. Then either out with drain plug at back of boat, bilge or just sitts in the hull
    Let it be!!!
      Yes there is a a hose that attaches to the bottom of the cooler liner and is directed through a hole cut out in the floor which drains into the bilge.
