Tap your backing plate and thread it down on the thruhull maybe.
Ever have one of those days?!?
Tigé Jedi
- Jul 2010
- 4302
- TN USA
However, I believe I have a simpler solution. I'm going to experiment with it later this morning and see if works.
As a side note, this also gave me the opportunity to confirm 100% fill of the annular ring around the thruhulls. There's little question of a solid watertight seal. Now the focus is on mechanical strength and integrity.Last edited by IDBoating; 06-07-2011, 07:16 PM.
Tigé Jedi
- Jul 2010
- 4302
- TN USA
Originally posted by WABoating View PostHere's a photo of the two handles, overlaid to show the misalignment.
I'll report back on what happens.
How did you end up with such a short through hull that barely has enough threads after passing through a 101/250" thick hull?
What thickness backing plate are you trying to use? I don't see why a 1/8" aluminum plate bonded to the hull wouldn't work.Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
Tigé Jedi
- Jul 2010
- 4302
- TN USA
Originally posted by chpthril View PostHow did you end up with such a short through hull that barely has enough threads after passing through a 101/250" thick hull? What thickness backing plate are you trying to use? I don't see why a 1/8" aluminum plate bonded to the hull wouldn't work.
So, as noted earlier, I very carefully backed off the flange nuts, which means:
This enables me to build traditional backing plates and bond them to the hull's inner surface, then use fresh flange nuts to secure everything.
Tigé Jedi
- Jul 2010
- 4302
- TN USA
Here's the finished product:
I knocked out three backing plates from 5/16th's aluminum plate. Three inches square each, with appropriately sized holes for the two one inch thruhulls and the one 3/4 incher. Each is rotated to best accommodate nearby objects (fuel tank, fuel line). They are bedded in FiberTech epoxy, intended to insure a perfectly level interface between the plate and the irregular hull surface (but not necessarily act as an adhesive).
After yesterday's frustrations, today was a much better day! Making progress, one step at a time....
Tigé Jedi
- Jul 2010
- 4302
- TN USA
Originally posted by WABoating View PostGood news: I emailed some photos and spoke with Curtis at Specialty Fabricators this morning, and they say they will try to build up and ship out a replacement handle today - thankfully skipping their normal three week backlog.
Sorry it happened, but glad to report that Specialty Fabricators takes care of their customers!
