I just replaced my serp belt. My was 5 years old and was making some belt type noise so I replaced as prevent maint. Took the old one off and took it to the auto parts store. During this process, I detected that my engine water circulating pump made a mild screech as I spun it with no belt. The bearing is going out. You may want to take a close look at that item as it will tend to cause a bit more damage if it freezes up perhaps more than the sea water impeller.
New Serpentine Belt
Consider the hours and age of the boat. The bearing in my water circulating pump squeels at higher rpm. when a greater load is placed on it,,,I expect that to worsen..I intend to wait till the off season. I suppose if your sea water impeller was binding,,it would cause a additional friction on the serp belt. Something must be coming close to ceasing.....
serpentine belt
Hi, i have a 2003 20v tige riders edition. i am from england and my serpentine belt has recently gone. i can give you an address if you would like to check up on it. i am sure they post worldwide. not sure how long it will be though. anyway. marinetech, stoke on trent, staffs, england. Hope it helpsCHECK out the BEAST!!!!!
