I have a 2007 RZ2 with an electrical issue. Turn the key and no chime and no start. Gauges come alive but nothing else. Trans in neutral, deadman switch in correct position. Had a great mechanic look at it and after many hours couldn't find the issue. Sent the ECM out, checked out fine and was flashed. Mechanic put the ECM back in and after checking more connections found a loose wire in a connector. He bypassed around the connector and it fired up. Brought the boat home and fired it up again. One month later after some detailing fired it up one more time. Thought it was fixed, but went to hit the river yesterday, same issue, turn the key, no chime, gauges come alive and no crank. Any suggestions or help in finding a local mechanic would be appreciated. Previous mechanic lives out of the area and is pretty busy.
Reputable mechanic in Sacramento area?
Originally posted by armes15 View PostI have a 2007 RZ2 with an electrical issue. Turn the key and no chime and no start. Gauges come alive but nothing else. Trans in neutral, deadman switch in correct position. Had a great mechanic look at it and after many hours couldn't find the issue. Sent the ECM out, checked out fine and was flashed. Mechanic put the ECM back in and after checking more connections found a loose wire in a connector. He bypassed around the connector and it fired up. Brought the boat home and fired it up again. One month later after some detailing fired it up one more time. Thought it was fixed, but went to hit the river yesterday, same issue, turn the key, no chime, gauges come alive and no crank. Any suggestions or help in finding a local mechanic would be appreciated. Previous mechanic lives out of the area and is pretty busy.I do all my own stunt work. hey ya'll watch dis.
I would revisit that loose connection thats seems to be a problem the first time. Look for an issue with the wire/terminal or maybe the terminal is not seated in the connector correctly.Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
