So, those of you that have access to your boat, would you be kind enought to take a look under it and see if your drive shaft existing the bottom of the boat towards the prop is centered in the hole or if it is slightly off center and if so, where? Off center description would be something like it's on the right side of the hole about 3 o'clock position, or it's down at 6 o'clock position.
Wondering if almost all the boats out there have drive shafts that are slightly off center or if most are centered up.
And if the drive shaft is off center, is this a BIG deal? If so, what should be done?
