Went to the lake this weekend and noticed my tower is loose, not sure how to tighten this up....ok, I think I know but looks like a major pain in the ars. The first pic is the left side, normal, the second pic is the right, there is about a 1/4" gap in the right and I can move it back and forth.
My tower is loose..recommendations please
It looks like an extreme tower mount.
Open the front lockers and look up. There should be a nut that you can tighten.
My boat is a Switch V and the other two (back legs) are harder to get to.
For the one on the left, remove the seat cushion and you will need a few socket extensions with a deep socket to tighten it. For the one on the left, you will need to remove the ice chest behind the driver and then use the same set up as you used on the left side.Attached FilesLast edited by whitlock87; 05-16-2011, 02:07 AM.Tige, it's a way of life!
