When I got my 24Ve, I was surprised that there was only a battery switch for the engine circuit. The accessory circuit had no battery switch, and the only way to make certain all power was completely cut off was to climb under the driver's console and flip the circuit breakers. Since you have to open the locker to turn off the engine switch, why not have a second one to handle the accessory circuit too?
Here's how things looked with a single switch:
I wanted the switches to match, so I picked up a Blue Sea model 6006 and a couple of other items:
...along with some four gauge marine rated cable and the associated ring terminals for 3/8 studs. I already had shrink wrap. I built two four gauge cables:
I then mounted the new accessory switch at the top of the locker and moved the existing engine switch up next to it. This will ease access if anyone should need to reach them with a full fat sac. The twin four gauge cables were routed over the top of the rear wall as shown.
After this last photo, I replaced a few tyraps and cleaned up the wiring harnesses in the battery compartment. I'm pretty happy with the way it turned out.
