I have my rzr in the shop, while I was there I stopped in to look at the proshop. I started talking about adding additional weight to my boat ( currently have 1600 surf system ). The guy said that we could add an enzo sac, and that it wouldnt be able to fill all the way but it would fill most of the way and add somewhere around an additional 800 lbs. After thinking on it I decided to go ahead with it and asked him to find out what they would charge to add it in while its there. He just called and said it would take 6 hours of work to plumb it in? So my question is, does that sound legit? I was assuming that with the current sac already plumbed in that they would pull that one out, lay the new one in and hook it up? What am I missing, at $105.00 per hours labor it sound aweful expensive!
plumbing in a enzo sac?
^^this is correct^^ Chpthril developed a custom sac that has fittings in the correct spots so that all you need to do is remove one sac and plug in the other. He calls it his "plug-n-play" solution. I got one for Christmas and started with the 1600 surf option as well. The hours that guy is quoting you probably is diong the work Chp has already done for you, either adjusting the locations of the fittings on the sac or the plumbing in the boat to accomodate one another. Chp will hook you up. The only thing is, he probably hasn't had a chance to verify the measurments on the RZR yet, but I'm sure its not that big of a deal. Also, my understanding is that the custom sac will fill more of the rear locker than a typical Enzo. Someone else that has already installed the custom sac can verify. I'm still waiting to get my boat out of storage to make the swap.
He replied on a earlier post I posted about wanting a bigger sac, but he hasnt done the measurements yet. He actually asked me to measure mine for him but i honestly havent had the time to do it. I am the type of guy that will pay extra for conveniance but do not want to be raped in the process. What kind of sace does he use?
Originally posted by leboeuf45 View PostHe replied on a earlier post I posted about wanting a bigger sac, but he hasnt done the measurements yet. He actually asked me to measure mine for him but i honestly havent had the time to do it. I am the type of guy that will pay extra for conveniance but do not want to be raped in the process. What kind of sace does he use?
If the RZR Surf/Pro is setup the same as the RZ and Ve boats, then my custom sac is a plug'n-play and take about 15 minutes to swap out. No additional plumbing.
Now, in RE to your question. With out know exactly how they are proceeding with the upgrade, its hard to say if 6 hrs is hi, low, just right. If they are just piggy-backing the enzo, then IMO, I think 6 is a bit much. If they are adding in new pumps and plumbing for the Enzo, then 6 would be about right.
If someone with an RZR with Surf/Pro option can get me a couple pics and a couple quick measurements, I can confirm if my current RZ/Ve custom will fit.Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
Originally posted by leboeuf45 View PostI have my rzr in the shop, while I was there I stopped in to look at the proshop. I started talking about adding additional weight to my boat ( currently have 1600 surf system ). The guy said that we could add an enzo sac, and that it wouldnt be able to fill all the way but it would fill most of the way and add somewhere around an additional 800 lbs. After thinking on it I decided to go ahead with it and asked him to find out what they would charge to add it in while its there. He just called and said it would take 6 hours of work to plumb it in? So my question is, does that sound legit? I was assuming that with the current sac already plumbed in that they would pull that one out, lay the new one in and hook it up? What am I missing, at $105.00 per hours labor it sound aweful expensive!
Has anyone replaced the front bag with something bigger or is this even possible?
