I just purchased a 2001 21V with the Merc 5.7.
Is there any way to easily empty the huge gas tank for towing or winter storage. confused: I notoced that the fuel pump seems to have 2 inlets and 2 outlets, and one of the outlets is closed off. Could I install a fuel hose with a shut off at the end of the hose there for de-feuling the boat. Syphoning worked a bit, but I kept gettng air as soon as it started to syphoe. If you pull off the rear tank cover to try to syphon, the angle of the inlet to the tank seems to cause the hose get air since it seems hard to keep the hose in the gas; besides that premium tastes aweful.
Any suggestions on how to de-fuel the boat. I would rather be ableto put the gas in my tank for the way home.
Regards
![Big Grin](https://www.tigeowners.com/core/images/smilies/biggrin.gif)
Regards
![Confused](https://www.tigeowners.com/core/images/smilies/confused.gif)
