My only suggestion, move it towards the back a little Ive messed around with my boat graphics and it makes the boat look longer and lower in the water when further back.
x2 on the naked. Less is more. Put a name on it instead.
So far as the graphic itself, no sir, I don't like it. IMO, too cartoony/too sloppy. It does not go with the boat at all. It's such a good looking boat with such clean lines that the sloppy cartoon "22V" does not work at all. Then the two almost tribal "W" type things with skulls inside? Negative. Doesn't it already say 22v towards the transom? Why would you need to put another 22v on there that is bigger and uglier? Ride naked.
My sincerest apologies if this offends you but, you asked for opinions and I would hate to see such a pretty boat end up with such an ugly graphic. 'Twould be a shame.
NO longer has the 22v on the rear has the chrome embroded TIGE bages. I dont like naked its getting something just not 100 sure yet. The new boats have the same type of cartoon as you put it 22ve on them
Just as fugly IMO.
Those chrome Tige stickers look bitchen. They do not, in any way, match the cartoony graphic. If you got the "chromies", I would do something with some class. Can your qraphic guy get the chrome vinyl? That would be dope if you did something in the same font as Tige.
