While winterizing my Tige at the beginning of this past winter I noticed some boat pox all along the hull under the water line. A friend advised me that I should leave it out of the water for the winter and the pox should dry up. A couple days ago I checked the hull for the first time since putting it up for the winter and the pox are still there. What is the best thing to do with the pox at this stage? How bad is this situation? Please help! see pics
Boat Pox
Originally posted by leboeuf45 View Postis that what people mean when they say the gelcoat blisters?
That sucks dude. I assume that you keep the boat in the water all summer? Is that water warm? Is it "dirty" in any way?
I wish I had good news for you but man, that thing looks bad. As bad as I've ever seen it. You're going to have to get it fixed and then get yourself an anti-fouling paint job on the "below the water line" part of the hull.You'll get your chance, smart guy.
Tigé Jedi
- Jul 2010
- 4302
- TN USA
Originally posted by wallacmc View PostThis is why I'm paranoid and won't leave the boat in water for more than two weeks.
Originally posted by NICKYPOO View PostOnly more so. Yikes! To the fiberglass shop! Pronto!
This is what I was afraid of. The boat stays in warm water half of the summer and on a trailer half of the summer. It just depends on how long between my visits to the lake house are.
Before posting my intial message I looked at several websites with pictures of blisters and I could not find any that look like the ones I have. Needless to say I was thinking this is very bad and after hearing what you all have to say it sounds like this is very, very bad.
Couple more questions if you don't mind...
I do not have a Tige dealer in my area. Should I take the boat to the nearest marina and have them service it or to a fiberglass shop?
Does anybody know the cost and time to repair something like this? The boat is a '97 so I'm wondering if the cost to fix it would exceed the value of the boat.
I had read on Tige's website about a lifetime hull warranty. Does anybody know what the deal is with that and if it would apply to this situation and a 1997 year boat?
Thank you for all of your help. I'm totally bummed out
Originally posted by willis View PostThis is what I was afraid of. The boat stays in warm water half of the summer and on a trailer half of the summer. It just depends on how long between my visits to the lake house are.
Thank you for all of your help. I'm totally bummed outIf its not fun, Why do it?
I believe we may be getting fooled by a slight illusion.Looking closely at the pics, it appears there is a reflection of, possibly gravel or whatever your boat & trailer are parked on. It does make it appear to have somewhat of an orange peel texture. If there isn't any orange peel texture, I think you are better off than what has been advised so far. "Hopefully anyway." Try some Mary Kates On Off hull cleaner and see if that doesn't take them all away. I have used it for tea staining on my hull and the results are fantastic.
Good luck...................I don't want to go to work, take me wake surfing instead!
Originally posted by scoot18 View PostI believe we may be getting fooled by a slight illusion.Looking closely at the pics, it appears there is a reflection of, possibly gravel or whatever your boat & trailer are parked on. It does make it appear to have somewhat of an orange peel texture. If there isn't any orange peel texture, I think you are better off than what has been advised so far. "Hopefully anyway." Try some Mary Kates On Off hull cleaner and see if that doesn't take them all away. I have used it for tea staining on my hull and the results are fantastic.
No lifetime warranty for a 97. Sorry to see it. There are others that have delt with this problem.
I tried a search for Gel Coat Blisters.
http://www.tigeowners.com/forum/sear...earchid=451372Mike Allen, Tigé owner since 1997
I have seen them bigger and that popped out farther but never so many per square inch. IMPO from what I can see in the pic they dont look like they are near popping. I am not a fiberglass expert but I bet your looking at thousands to fix that. Taking in the age of the boat. I would look at painting the bottom and using the boat. The blister are not going to affect the function of the boat. So I would try and keep it from getting worse and use the boat as is. Now if they continue to get worse you will be forced to do something but if you paint the bottom You should be ok. I would check with a fiberglass guy and see what he says. Let us know what he says and what you decide to do.Good Luck.
