2007 RZ2
    2007 RZ2
    The 2007 RZ2 has a lower weight than the 08 thru 11 (which all are the same) does anybody no where the extra weight is added in the newer models? And what other changes have been made since 07
    i know the seats are different,the tower is different. the newest models have a PCM MOTOR.also tige touch.the factory ballast has more levels900 lbs base 1600 lbs surf and 2000 lbs pro ballast.as far as the hull and structure of the boat i don't know any difference.maybe someone else can chime in on that.
      It shouldn't be the tower or options, they are not included in the dry weight.
