Originally posted by Timmy!
View Post
Tow Rig Questions and Opinion
Tigé Jedi
- Jul 2010
- 4302
- TN USA
Tigé Jedi
- Jul 2010
- 4302
- TN USA
Originally posted by Wickedcummins View PostYah in a AUTO. Yah the NV5600 is a cast case the G56 is a aluminum case and a bit stronger.
(Another good reason was that I was able to negotiate a KILLER price. I called the dealer on 01 January 2006, which a little research ahead of time revealed to be the last day of the dealer's fiscal year. They were REALLY motivated. Worked great!)
Originally posted by Timmy! View PostHow is the gas mileage in the 6.0 Av vs the 5.3? I had an '03 Avalanche and only got about 6 mpg towing my RZ2 but I live at altitude. The 5.3 could only pull the RZ2 in 4th gear when it was basically flat, any hills and it needed to downshift into 3rd and it run at a higher rpm.
To the OP. I would look for excursion I searched for some time and found a clean low mile that had the 7.3L powerstroke etc. I get around 15-16ish towing going 80-85 pulling some step mountain gardes passing others. If I want to take all day and go 65 I get 20-21 range. You will hate towing going from a diesel to a gasser. My 93 dodge 5.9L dually (2wd stick) did get better mileage but also had to tow slower due to gearing ( really needed a six speed)
Another tid bit of info that you dont see mentioned alot is tail gate open or closed or tail gate grille bar, I got to see data on the wind tunnel testing and tail gate closed netted better fuel economy then open or grille, you can accually see in the testing a bubble build up in the bed and then the air smoothly flows across the roof and bubble and kills drag, with the tail gate down or grille a pressure drop occurs under the bed and puts a drag on the truck.
Originally posted by carter View PostI got about 8-9 with the 5.3 4speed and 10-11 with the 6.0 6speed. I equate this to a bigger engine having to work less and the 6 speed tranny. With less gaps and a more effective tow/haul mode, it would find the sweet spot better.I love the power of the diesel but it's hard to beat that cushy ride and versatility that the Av gives you.
Originally posted by Timmy! View PostThanks for the info! I really miss my AvalancheI love the power of the diesel but it's hard to beat that cushy ride and versatility that the Av gives you.
Tigé Jedi
- Jul 2010
- 4302
- TN USA
Originally posted by dom w. forte View Postyou can accually see in the testing a bubble build up in the bed and then the air smoothly flows across the roof and bubble and kills drag, with the tail gate down or grille a pressure drop occurs under the bed and puts a drag on the truck.
Obviously this would work on gasoline powered trucks too.
Mythbusters did a whole thing on that.
For the original myth they did a driving test and a water vortex test, both of which showed that you save more gas with the tailgate up. Their viewers suggested that they test three new conditions:
Hardroof cover over pickup bed
Mesh tailgate
Remove the entire tailgate
They had a much simpler test setup this time. They had an electronic flowmeter hooked into fuel line of Jamie's pickup. Adam: "For anyone out there that wants to e-mail telling me that we screwed up this test, we have already calibrated this thing, to this car. So it's going to be perfect!" They drove the pickup truck up and down the stretch of 101 around Candlestick and the Cow Palace.
Tailgate down: 5.2 gallons/hr @ 55mph. 1.2 gallons/hr @ 25.
Tailgate up: 5.0 gallons/hr @ 55mph. No reading for 25mph given, but tailgate up was once again confirmed as more efficient.
Hardcover over pickup bed: 5.0 gallons/hr @ 55mph. 1.2 gallons/hr @25mph
Tailgate mesh: 5% more efficient
Tailgate removed: about the same as tailgate up and hardcover
Mesh was most efficient by 5%
Originally posted by Wickedcummins View PostYou must stop by and see one now then. All changed dodge truck is as comfy as a lexus. Seats are heated and Air conditioned hole new dash seats and sound systems.. And they ride killer.
