I asked, and here is the cut-and-paste quote from Tige Engineering. Misspellings and other errors are theirs.
So there you have it. This parallels the cautions from every other boat manufacturer I've researched. Tow from the pylon at your own risk. I will be installing a dedicated tow ring in the transom, probably integrated with the grab handle as discussed in another thread.
Hope this ends the dispute. Thanks!
Ski pylon's location was not designed to handle the higher impact force that is produced from tubes and some inflateables. The force put onto the pylon by the skier is limited by the amount of force the skier itself can possibly hold in their hand(s). The inflateables tends to be tied onto the boat with no way of releasing the force unless the rope or the device holding the rope breaks.
Pylons are only for skiers and boarders. No inflateables are allowed.
