Well, crap. The boat is put away for the winter. I must say winter for me is only until January 1 2011 then it will be out and running for the polar bear plunge.
I do have a problem and frustration though. When I bought this boat some of you will remember all the problems it had.
Well one of those problems was the Gel-Coat cracking around the D-Hook on the front. Well when I was putting it away yesterday guess what. In the exact same spot as when the boat was new is a Gel-Coat crack.
I guess I have a couple of months to get the Gel-Coat and Fiberglass fixed. I will be spending the next couple of weeks learning how to mix and spray Gel-Coat. I guess the people that repaired it last time did not do something right to fix it I will have to go after fiberglass repair this time and make sure the fiberglass is ok. It is weird the crack is in the exact same location as before.![Mad](https://www.tigeowners.com/core/images/smilies/mad.gif)
