OK, So I'm sure everyone here has their own way to pick up your downed rider.
First off if your power turning all the time then your risking allot of unwanted water to douse everything and everyone. Not to mention getting all of our cloths in the storage wet...and having to put in work drying everything out. Especially if your weighing down your rig with ballast & Sacks.
Here is the way I do it...
1. Your rider falls.....
2. Put throttle in neutral position and slightly turn the steering wheel to the left allowing the boat to rest in the water with a slight left turn
3. Once the boat has rested out of a plane, put the throttle in the reverse position, not gunning it but just until it engages reverse.
4. The left turn you made was to posistion the rope to the left rear of the boat allowing you to engage reverse without running over your rope!...reverse will back you out of the huge rollers your boat has made and let them roll on by in front of you
5. Once the rollers have now past you..engage your throttle to forward position only letting your RPM to 1000 or just under(not creating another wake) and go pick up your rider.
IMO the best way to do it. I know that conditions may be different at different times, such as other boats near by or a shark in the water
My boy didn't listen to me on how to do this technique and now I am drying out my boat
ok...im done ranting!
anyone agree with this way?
