Hello to every body im new to the forum.
I just bought a used 2006 24v with 6 liter, with 20 hours. I am in the process of working all the bugs out. The problem I am having is either prop slip/cavitation or transmission slip. If I accelerate hard from a dead stop the boat pulls great up to 4000 rpm. Then it slips and the engine revs. I am unable to get above 4000 rpm with out slipping wether I accelerate hard or easy. I just sucked the fluid out of tranny and replaced (fluid still pink, not burnt smelling). Then ran boat to warm it up, shifted into nuetral and immediatley checked and filled to full using this method. I got 1 1/2 quarts into tranny. Tranny capacity is 2 quarts, I dont know if I got it all out when I drained, or do I need to add more. Or is the prop slipping (acme 537)? I keep thinking that if the tranny was slipping it would do it on the low end under hard acceleration, not at 4000+ rpm. Any insight would be greatly appreciated.
