Originally posted by laserfish
View Post
Serious proof of the ConvexV hull!
It's always an option, just depends on how much money you want to spend. You could get a through hull installed and put a plug in it, and modify (chop up) the floor, put a little access hatch in it and call it an option.2009 RZ2, PCM 343, MLA Surf Ballast, Premium Sound.
Originally posted by talltigeguy View PostMany boats have the lowest point in the hull in the center, including mine. I have a forward drain in my boat in fact.
Unfortunately, Tige is constructed such that a forward drain hole is apparently impossible to have on the V-drives. I always found this to be annoying on my 05 24V. I would usually just leave it open and it will eventually evaporate out. It did help to go to the steepest hill I could find, park on the hill, jack the tongue up on the trailer, and I could get most of it out. (I would keep the boat attached to the hitch so I didn't have to worry about the boat rolling away, and I could get a good 6 inches of rise out of the front on top of the angle of the hill).Cursed by a fortune cookie: "Your principles mean more to you than any money or success."
