If anyone had plans to launch at either Callville or Echo for a little while, you should check if the ramps are open before you drive to either location.
Isolated thunderstorms blew through the area on Monday, and resulting flash floods did some significant damage to Callville Marina (luckily, it seems that no private boats were damaged). The same storm system also washed out the dirt access road to the ramp at Echo.
Until they open back up, the only available ramps are at Hemenway or Temple Bar.
http://www.lvrj.com/news/after-the-s...104390839.html
http://www.lasvegassun.com/news/2010...e-estimated-1/
