Don't worry, not trying to start a fight, or pissing war. I have just been trying to wrap my noodle around a few things. We took the 24Ve out on Saturday to see what would happen if we added more weight to the rear corner than usual, and started adding weight to the front. The weight up front seemed to destroy the wave. The RZ2 needs weight up front, but its more than just the extra 2 feet. They don't seem to react similarly, and I started thinking.
When you order a surfboard from say The Walker Project, and you order a 4.5. And then you order a 4.9 of the same board. The boards act the same, just take different weighted riders. I was applying this thought to the 22 vs 24 tige boats. Same hull, should act the same, just different proportions. But then, I realized that that is not the case. When you take a 4.5 board to 4.9, the blank is made by a CNC machine with a CAD file. So to make the bigger board, they just scale the drawing until its 4.9. So the board is the scaled the same all around to the new size. Its a bit wider, thicker, etc.
When they make an RZ2 from an RZ4 or vice versa, I think the only difference is the length. So its still the same beam, the same freeboard, etc, just the 24 foot version is 2 feet longer. So its really a different boat, and I think more different, at least when it comes to surf wake, then one would expect.
Anyway, I am just noodling it. My 24Ve made a great wake, and we loved it. I never considered it a competition level wake, but great all the same.
Our RZ2 surf wake, though, has blown me away. I think the hull shapes have to be similar enough, that competition level wake could be had from our 24Ve, but its going to be a much different formula. I am guessing that a 24Ft boat, should be treated like a 22 foot boat that already has a BUNCH of weight in the front. I am thinking its maybe as if the 24 foot boat acts like a 22ft boat with 500+ lbs already up front.
I am guessing for wakeboarding, since you weight the whole boat down, this isn't an issue, the 24 foot boat would def be the better.
Anyway, just noodling, what are your thoughts?
