So a friend of mine recommended the Boat Buddy since he has had it on many of the MC's he's owned over the years. I relied on him to teach me about general launch & retrieval on inboards and he suggested I get a Boat Buddy on the trailer. I went online, read the good and the bad, and decided; it's only $100 and the promise of my wife not getting her feet wet convinced us to try it.
The Boat Buddy is a spring loaded pin which is triggered by your boats bow eye and secures the bow eye to the bow eye stop. It makes a pretty loud snap sound when it is activated by the bow eye so you know the boat is on the trailer. Many people pull the boat out of the water only held on by the Boat Buddy but I have been reaching over the bow, attaching the winch strap and taking the pressure off the Boat Buddy.
It's made or at least seems to be made and sold by Kodiak Trailer Components and is also available through Bass Pro Shops and Overtons. Most retailers market the Boat Buddy for bass boats but it's also standard on many MC trailers. You can see how helpful it can be for a closed bow boat.
Pros: Lets you know when the boat is in the proper position to turn off the engine, lets you easily attach and tighten the trailer winch.
Cons: plastic is not very strong and does not take abuse well. Plastic housing can leave smear marks on your bow but it is easily removed with Babe's and a little elbow grease.
My friend helped me and showed me how deep I have to put the trailer to use just a little power to finish the last few inches and get it to snap. You can experiment on your own to find the correct water level/trailer depth to have an easy contact and not destroy the mechanism, but you might break your Boat Buddy in the process.
From the MC forums I have learned it works very well if you attach bunk carpet to the top of the unit that contacts the boat and prevents smear marks on your gelcoat. I plan to do that soon.
I also keep my original roller in the boat just incase the Boat Buddy breaks and I need to revert back to the original bow stop.
Here are a few pics: I'm going to keep it on the trailer and use it gently. My crew likes it and we have incorporated its function into our launch/retrieval process.
