So, I have already put close to 50 hours on this boat, but we are having intermittent issues with the front ballast. It usually happens when we first head out, and try to fill front. You can't tell if its filling, the % guage is based on timer, and they are sealed. The pump is running, but then after the amount of time it should take, the sac isn't filling and overflowing. The overflowing is the only indication, other than maybe the boat feeling weighted.
We have learned to fill for a bit, then try to drain and see if anything is in there. Then we try to reverse, pull forward, try to prime that pump, nothing. Can't find anything wrong or pinched. Then, we give up, but then for some reason, an hour later, it will just work. Has anyone else experienced this? It also seems to effect both sides when it happens, but not always. The last 3 times we have been out, more than likely it doesn't work at first, and then an hour later or so, it does.
If anyone else has a quick fix, or something to look for, that would be great.
