Correct, I you invented, he makes them, that is what I meant, but stated it incorrectly.
"darndest time" didn't refer to me getting one, referred to you being able to provide, and you didn't seem willing or able to do that.
The 600lb/400lb issue, I was simplifying what I understood. That it is possible for a pin to become damaged and not break, and then break later at a lower weight. And so therefore are not set and forget, but need to be inspected.
You did mention that you didn't want to promote for tubing, due to possiblity of pin breaking and sending someone out on a whip, I extended that to be possible for wakeboarders also, especially if a pin had been unsuspectingly damaged. I do not completely recall the issue on tubing vs. wakeboarding. But it seemed you were definitely nervous about people using it outside a certain scope. I will take your word about wakeboarding and wakesurfing, I could have misunderstood you.
There are no hard feelings.
