We took the boat out this weekend (for another great weekend of boating), but I noticed one strange thing . . . the engine hours meter on the boat seems to have reset. Everything else seemed to work as usual. Has anyone ever had this happen? What would cause it? My fear is that it might be an indication of a larger problem . . . but like I said, everything else seemed to work perfectly all weekend. If it helps, I have an 06 22i.
Hours Meter
There are a few threads on this topic. It sounds like most of the problems are with Faria Gauges. The real hours are stored on the ECU and can be retrieved with the proper tools. It seems it might reset due to low voltage or even charging the battery.
Try a search using hour meter reset or hourmeter reset. Good luck.Mike Allen, Tigé owner since 1997
Originally posted by TeamAllen View PostThere are a few threads on this topic. It sounds like most of the problems are with Faria Gauges. The real hours are stored on the ECU and can be retrieved with the proper tools. It seems it might reset due to low voltage or even charging the battery.
My son found a way to add the hours to the hour meter. It worked well.
Here is the contraption that he built.
http://www.tigeowners.com/forum/show...digital+analogMike Allen, Tigé owner since 1997
