Where is the location of shut off valve
    Does anyone know the location of shut off valve and how it looks like in 2010 PCM 6.0L engine?
    As I need to switch off the seawater intake and allow fresh water to flush the engine. THX
    Do you just want to start the boat without being in the lake? If so, you need a fake a lake that is basically a plunger that you hook up to the garden hose and then place over the seawater intake to start it up.
      No!! Actually my boat is equipped with fresh water flush kit.
      I have to flush the cooling system everything after use.
      Therefore I need to shut off the valve manually in order to block the seawater intake and allow fresh water to clean the system.
      That's why i need to know where is this shut off valve..
        I just looked at our 2010 in stock like I told you it is on the intake scoop. Now this boat does not have a factory flush kit but I can pretty much assure you they put it in the same place. On the water intake scoop port side down low about middle of the eng. sticking up through the hull. DID YOU LOOK at the scoop like I suggested to you yesterday????
          Pics?
            Why do you have to flush everytime? Are you in Salt Water?
