Fresh water flush kit
    I just received 2010 tige RZ4 and I found problem in using the fresh water flush system. This is a yellow knot very close to the engine pipe where I canot really turn in order to let fresh water to clear the fresh water cooling system.
    Does anyone can give me a solution. Many thx
    Huh? I hate to tell you this but, your writing makes it almost impossible to tell what your talking about. I have a feeling this is why I'm the first to respond to your question. Maybe you could post a picture or something.
      Ok I make it clear. I cannot find the shut off value (seacock) to prevent the intake of seawater and let fresh water to clean the cooling system.
        go under boat find intake scoop...note postion of said scoop..go inside boat and look for the scoop on the inside....either attached to that scoop or follow hose comming off of scoop and there will be a shut off valve. I can look 2morrow and tell you for sure where it is. ..but the bottom line is find the intake scoop and it will be on it or very close to it.
          I have the water strainer and flush kit on mine and the shut off valve is on the bulkhead at the back of the engine(inboard side, not transom side). If you open the engine hatch cover and look straight down and slightly to the left there is a large plastic see through strainer housing and a plubing shut off valve (like what would be used in your home) with a long straight handle. In line with the intake hose, is open, turn purpendicular to the intake hose, that is closed. Unscrew the cap for the hose hook up, screw on your garden hose, turn on the water, and fire up the engine.
          I don't want to go to work, take me wake surfing instead!
            Hi Scoot18,
            Thank you for your info.
            It is very clear answer. But unfortunately, my PCM 6.OL in RZ4 does not have this arrangement in the engine hood.
            I sent email to the Tige production director, they send me a old layout rather than mine.
