Prop Change 2010
    Prop Change 2010
    I have a 2010 Rz2 with the pro ballast option in it and once you get people, gear, and extra weight added in the boat takes forever to plane out anybody have any advice on to which prop one should think about upgrading to?
    If you have the 537, then the most popular upgrade is the 1235. It's never a bad idea to gather your info and run it by the pros at ACME.
      X2
