I've been experiencing problems with my 2002 Tige 21V RE, Black Scorpion 350 cid. Boat starts fine and will run great for about 5 minutes at which time it starts to sputter/cough until I pull back on the throttle. Boat will idle fine, but when I give it gas again it will start to sputter again within 20-30 seconds. If idle longer and throttle up I can go 2-5 minutes before it starts to act up. If I give it more gas when its sputtering it will eventually backfire. It doesn't matter what RPM's it will still do it. I've replaced the fuel pump, fuel pressure regulator and the fuel filter.
Has anybody else experienced this problem?
