Similar but Different Limp Mode
    2007 24ve. 197 hours. Oil level good. Oil PSI 57, Temp 154, Trans fluid level good. Volts 13.5. MarinePower 5.7. Factory EIRB and TigeSpeed Set. DID put in ballast system over winter with 2 new switches for the pumps however.
    Audio alarm has sounded while cruising at 25mphish--3000 rpm. The alarm sounds and the RPMS drop. I bring back to neutral, which stops alarm, then I can put back into gear and the alarm doesn't sound again for rest of day.
    Does NOT happen in neutral or going into gear, does NOT happen when I pin it to Wide Open Throttle, does NOT happen when pulling boarders 22mph or tubing 20-25mph or surfing at 10mph. So far, only happens once per day, generally as I am driving to where we'll board/ski for the first run. First noticed @ 187 hours--now experienced 3 times.
    I've read forums about flashing ECM, about the potentiometer issue and the paddlewheel/speed sensor issue. It sounds like it could be any/all of these.
    I've posted same issue on the MP website, no response yet. (I'd like Eddie's email if someone can PM it to me or post it here). My local dealer dropped selling new boats but still does TIGE warranty and will come out with his laptop to check any codes--but probably not for a week or two.
    Anyone else experienced/solved this--or should I be worried about driving it til I get resolved?
