5.7 L Vortec engine
When the key is on, the buzzer sounds continuously. Once started, buzzer still on and engine won't rev up. No throttle response. (Limp Mode)
I'm trying to figure out what has put it in limp mode. All fluids at proper levels and gauges look correct. Knock sensor is connected. Good batteries with good grounds. I've read about bad throttle position potentiometers and tested it with the following readings:
5kV at idle to 1.3kV at full throttle
Is this a normal reading?
What else should I check for that would cause limp mode?
Many thanks!
Many thanks!
