I finally got it home today, my "new" 2009 RZ2. I didn't have time at the dealer to figure out how to set up the Bimini so here is my shot at it. But first, a pic of the boat:
First question is, did I set up the bimini correctly? the rear bar seems to drop down at the sides as if the two posts that slide into the back of the tower are out of adjustment.
Second question, as I was fiddling with the bimini, I tried turning on the stereo and found that none of the accesories were working. i made sure the battery was turned on, if has factory dual batteries but none of the lights, radio, blower are working. I checked the battery cables and the CB panel under the dash. If I turn the key to the left or just one click to the right (not starting the engine) the info screen pops up and tells me the temp and all the other info, but the accessories still don't work. I had the boat on the water at the dealers test lake yesterday and everything worked fine, what am I not doing? I'll keep reading the owners manual tonight but I read through it last night and didn't see anything describing my situation.
Thanks in advance
Thanks in advance
