Had our Z1 in the water for about 45 minutes of slow cruising. Didn't realize shower valve was on. Toggle switch for shower was off but still filled hull with enough water some was injested into engine. Thankfully boat is ok but just a heads up.
shower valve on
Why was it leaking into the bilge? I would think that the bilge pump would kick on and the floor would be getting wet long before the water level reached the flame arrestorWater that high would sink a boat
Glad nothing major happened.Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
Originally posted by canyonferry View PostHad our Z1 in the water for about 45 minutes of slow cruising. Didn't realize shower valve was on. Toggle switch for shower was off but still filled hull with enough water some was injested into engine. Thankfully boat is ok but just a heads up.
