Annual Maintenance Questions
    I am sure there is a thread on here somewhere regarding this, if so can you point me there?
    If not, I am thinking of doing the annual service myself minus the impeller. Does anyone else do this? Does anyone have a checklist of what to complete other than changing the oil?
    Impeller question, can you get away with changing this every other season?
    Thanks in advance.
    I always did everything. the impeller isn't that hard...
    Originally posted by G-MONEY
      I change the impeller every year, break one and ruin a weekend and you will too. It's cheap insurance. But also if you use it year round you don't need to. It's the sitting not in use that destroys it.
      I would always change oil, impeller and grease the joints and that's all I did every year. Changed the fuel filter and water seperate every other. but also it all depends how many hours you use your boat.
        Thanks Domsz
        Do you have any directions or steps you take to complete these? I am comforable doing this, I just havent yet. Once I do it once I'll be good.
          i didn't have any i'm sorry. I Just took the belt off, disconnected the tubes going to the pump, there was 3 bolts, took those out and then took the 6 small bolts out of the impeller housing.
          Sorry about not having any steps or anything. I'm the kind of person that takes it a part and then puts it back together....
            What engine do you have?
            Common Sense is not so Common
              Engine
              I have a 2002 20i, with the 350 Mercruiser.
                I think there is a Merc sticky thread in the how-to section.
