Seriously, check the RCA connections on the back of the head-unit. Did you swap the left and right chnls, or just unplug and replug? Swap them and see if the problem stays on the left or moves to the right.
i think that can be arranged let me know when you are availabile.
Do you have all your post on your ballast install it seems when i pull it up im missing the first parts of it
Hmmm, haven't looked at that thread in awhile.
If you face the opposite direction and the left speakers still don't work, I recommend a hearing test.
If the RCA cables are in correct, and the balance is correct. Try changing the left and right RCA cables at various points to identify if it is the head unit or amplifier.
