Get a bimini like mine and you will be in the shade. I have the grey also. it does get hot. Leaving tomorrow for 10 days in Havasu. Water ia almost 80, air about 110. looking forward to no work.
2006 Tige's
My dealer won't tell me anything, but one of the riders did tell me that there will be a 24v with a walk through transom like the 226 has. I hate walk through transoms, but apparantly someone thinks they are a good thing.
The 22 and 24 could have more usable space inside if they blocked the rear. Sure the 24v is bigger than the Malibu LSV, but the interior space is the same.
Top option I woudl want would be full snap out carpet. I am tired of it getting wet and stinky.
I see Andrew is still alive. (Maybe the reply button on his email is not working)
Do you think the 06 will be properly balanced or will you have to put an additional 200lb's plus on the passangers side to make a decent wake ilke my 05?
or was the balancing of a boat an upgrade on the 05?
Sorry to bring everyone else in on this but I can not seem to get Andrew to return any of my emails.
Kelsh
BRD4FUN
I have not received another e-mail from you since our last coorespondence on 6-23-04 where you asked for any suggestions for adding addition weight in your boat. I still do not have an answer where you can place more weight. You run anywhere from 600-900 lbs in the nose section of the boat. I feel you are running too much weight as stated before. I have no suggestion on adding more weight. If you have sent any e-mails since the date above I have not received themand please forward them to me at tigeman@tige.com. If you would like to speak to me please give me a call @ 325-676-7777. For the record, I do answer all of my e-mails.
Call it morbid curiosity, but has Tige considered ballast under the walk through area? I know a guy did it to his boat, but when I checked into having mine done I was told it would void the warranty. Is this possibly an option in 2006. This type of ballast placement is common on cometitor brands is why I ask if Tige has considered this now. Most competitors have 500-600 lbs in the walkthrough, leaving the nose open for more ballast or storage.
